メインコンテンツにスキップ
Dell Latitude 3189 Speakers Replacement
必要な工具と部品
  1. Dell Latitude 3189 Speakers Replacement, Lower Case: 手順 1、 2の画像 1 Dell Latitude 3189 Speakers Replacement, Lower Case: 手順 1、 2の画像 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Speakers Replacement: 手順 2、 3の画像 1 Dell Latitude 3189 Speakers Replacement: 手順 2、 3の画像 2 Dell Latitude 3189 Speakers Replacement: 手順 2、 3の画像 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Speakers Replacement: 手順 3、 2の画像 1 Dell Latitude 3189 Speakers Replacement: 手順 3、 2の画像 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Speakers Replacement: 手順 4、 3の画像 1 Dell Latitude 3189 Speakers Replacement: 手順 4、 3の画像 2 Dell Latitude 3189 Speakers Replacement: 手順 4、 3の画像 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Speakers Replacement, Battery: 手順 5、 2の画像 1 Dell Latitude 3189 Speakers Replacement, Battery: 手順 5、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Speakers Replacement: 手順 6、 2の画像 1 Dell Latitude 3189 Speakers Replacement: 手順 6、 2の画像 2
    • Grip the battery and lift it up and out of the chassis.
  7. Dell Latitude 3189 Speakers Replacement, Speakers: 手順 7、 1の画像 1
    • Use the flat end of a spudger to push the white plastic speaker connector out of its motherboard port.
  8. Dell Latitude 3189 Speakers Replacement: 手順 8、 2の画像 1 Dell Latitude 3189 Speakers Replacement: 手順 8、 2の画像 2
    • Lift out the right speaker.
    • Lift out the left speaker.
    • Before removing the speakers make note of how the wire between the right and left speakers are routed within the chassis.
終わりに
作成者
2人の作成者と共同で作成されました。
Bryan Pratt
メンバー登録日: 02/14/24
601 ポイント
6のガイドは作成済み
チーム
University of Memphis, Team 2-3, Sneed Spring 2024 University of Memphis, Team 2-3, Sneed Spring 2024人のメンバー
UM-SNEED-S24S2G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 34
