メインコンテンツにスキップ
Dell Latitude 3189 Keyboard Replacement
必要な工具と部品
  1. Dell Latitude 3189 Keyboard Replacement, Lower Case: 手順 1、 2の画像 1 Dell Latitude 3189 Keyboard Replacement, Lower Case: 手順 1、 2の画像 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Keyboard Replacement: 手順 2、 3の画像 1 Dell Latitude 3189 Keyboard Replacement: 手順 2、 3の画像 2 Dell Latitude 3189 Keyboard Replacement: 手順 2、 3の画像 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Keyboard Replacement: 手順 3、 2の画像 1 Dell Latitude 3189 Keyboard Replacement: 手順 3、 2の画像 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Keyboard Replacement: 手順 4、 3の画像 1 Dell Latitude 3189 Keyboard Replacement: 手順 4、 3の画像 2 Dell Latitude 3189 Keyboard Replacement: 手順 4、 3の画像 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Keyboard Replacement, Keyboard: 手順 5、 3の画像 1 Dell Latitude 3189 Keyboard Replacement, Keyboard: 手順 5、 3の画像 2 Dell Latitude 3189 Keyboard Replacement, Keyboard: 手順 5、 3の画像 3
    • Flip up the black lock bar on the ZIF connector with a plastic spudger.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Gently pull the ribbon cable directly out of its socket.
    • This should require almost no force.
  6. Dell Latitude 3189 Keyboard Replacement: 手順 6、 2の画像 1 Dell Latitude 3189 Keyboard Replacement: 手順 6、 2の画像 2
    • Use a blunt tool to push through the two highlighted holes labeled "KB." This will dislodge the keyboard.
    • The keyboard will be removed from the opposite side.
  7. Dell Latitude 3189 Keyboard Replacement: 手順 7、 1の画像 1
    • From the front side of the laptop, pull the keyboard up and away.
    • Pulling the keyboard away will be undoing plastic clips and maybe require more force than you initially think. Slide opening picks around the perimeter to help disconnect the plastic clips.
終わりに
作成者
3人の作成者と共同で作成されました。
Bryan Pratt
メンバー登録日: 02/14/24
601 ポイント
6のガイドは作成済み
チーム
University of Memphis, Team 2-3, Sneed Spring 2024 University of Memphis, Team 2-3, Sneed Spring 2024人のメンバー
UM-SNEED-S24S2G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 67
