メインコンテンツにスキップ
Dell Inspiron i3558-5500BLK Wireless Card Replacement
必要な工具と部品
  1. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: 手順 1、 2の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: 手順 1、 2の画像 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 2、 3の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 2、 3の画像 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 2、 3の画像 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: 手順 3、 3の画像 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: 手順 4、 2の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: 手順 4、 2の画像 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 5、 2の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 5、 2の画像 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 6、 3の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 6、 3の画像 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 6、 3の画像 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 7、 2の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 7、 2の画像 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 手順 8、 3の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 手順 8、 3の画像 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: 手順 8、 3の画像 3
    • Identify the Wireless Card as shown in the image.
    • Remove the power couplings by gently pulling them away from the assembly.
  9. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 9、 2の画像 1 Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 9、 2の画像 2
    • Remove the 1 mm Phillips screw shown in the image.
  10. Dell Inspiron i3558-5500BLK Wireless Card Replacement: 手順 10、 1の画像 1
    • Gently pry the wireless card upward from the screw-side and pull outward toward the edge of the laptop to remove.
終わりに
作成者
3人の作成者と共同で作成されました。
Nathan Ybanez
メンバー登録日: 09/27/17
622 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G5
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 18
今までの合計 570
