メインコンテンツにスキップ
Dell Inspiron i3558-5500BLK Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron i3558-5500BLK Hard Drive Replacement, Keyboard: 手順 1、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement, Keyboard: 手順 1、 2の画像 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 2、 3の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 2、 3の画像 2 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 2、 3の画像 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Hard Drive Replacement, Battery: 手順 3、 3の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement, Battery: 手順 3、 3の画像 2 Dell Inspiron i3558-5500BLK Hard Drive Replacement, Battery: 手順 3、 3の画像 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Hard Drive Replacement, Back Cover: 手順 4、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement, Back Cover: 手順 4、 2の画像 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 5、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 5、 2の画像 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 6、 3の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 6、 3の画像 2 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 6、 3の画像 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 7、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 7、 2の画像 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 2
    • Identify the hard drive as shown in the image.
    • Remove the 0.5 mm Phillips screws that secure the hard drive to the palm-rest.
  9. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 9、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 9、 2の画像 2
    • Disconnect the hard drive ribbon cable from the mother board as shown by lifting the release tab and gently pulling the cable away from the socket.
    • To avoid data loss, do not remove the hard drive while the computer is on, or in sleep mode.
  10. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 10、 1の画像 1
    • Carefully lift the hard drive off the palm rest.
    • Hard drives are fragile. Exercise care when handling the hard drive.
  11. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 11、 1の画像 1
    • Disconnect the interposer from the hard drive.
  12. Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 12、 2の画像 1 Dell Inspiron i3558-5500BLK Hard Drive Replacement: 手順 12、 2の画像 2
    • Remove the 0.2 mm Phillips screws that secure the hard drive bracket to the hard drive.
    • Lift the hard drive bracket off of the hard drive.
終わりに
作成者
3人の作成者と共同で作成されました。
Joe Giesa
メンバー登録日: 09/27/17
104 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G5
4 メンバー
13のガイドは作成済み
コメント 1 件
Hi, appreciate your guide. What size hard drive will fit in here? I’m trying to replace it with an SSD, but want to get it right. Thanks!
Dean Tripp - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 24
今までの合計 1,422
