メインコンテンツにスキップ
Dell Inspiron One 2020 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 手順 1、 3の画像 1 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 手順 1、 3の画像 2 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 手順 1、 3の画像 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: 手順 2、 3の画像 1 Dell Inspiron One 2020 Hard Drive Replacement: 手順 2、 3の画像 2 Dell Inspiron One 2020 Hard Drive Replacement: 手順 2、 3の画像 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: 手順 3、 3の画像 1 Dell Inspiron One 2020 Hard Drive Replacement: 手順 3、 3の画像 2 Dell Inspiron One 2020 Hard Drive Replacement: 手順 3、 3の画像 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 1 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: 手順 5、 2の画像 1 Dell Inspiron One 2020 Hard Drive Replacement: 手順 5、 2の画像 2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: 手順 6、 3の画像 1 Dell Inspiron One 2020 Hard Drive Replacement: 手順 6、 3の画像 2 Dell Inspiron One 2020 Hard Drive Replacement: 手順 6、 3の画像 3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
    Excellent guide, was a super easy swap. I put an SSD in it!!
    Matt Yakel - 返信
    Hey Just one question, is the HDD SATA 2 or SATA 3? Just wanted to know so I can purchase an SDD with the correct specification.
    Jeffery Epstein - 返信
終わりに
35 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Tyler
メンバー登録日: 06/19/12
4,920 ポイント
16のガイドは作成済み
チーム
TechForce TechForce人のメンバー
Business
2 メンバー
25のガイドは作成済み
3 件のコメント
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - 返信
Good Job, short and sweet and easy to follow
schmidtrg - 返信
Really useful information thank you.
Jessie Colon - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 72
今までの合計 35,702
