メインコンテンツにスキップ
Dell Inspiron N5050 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: 手順 3、 2の画像 1 Dell Inspiron N5050 Hard Drive Replacement: 手順 3、 2の画像 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: 手順 5、 2の画像 1 Dell Inspiron N5050 Hard Drive Replacement: 手順 5、 2の画像 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: 手順 6、 3の画像 1 Dell Inspiron N5050 Hard Drive Replacement: 手順 6、 3の画像 2 Dell Inspiron N5050 Hard Drive Replacement: 手順 6、 3の画像 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: 手順 7、 3の画像 1 Dell Inspiron N5050 Hard Drive Replacement: 手順 7、 3の画像 2 Dell Inspiron N5050 Hard Drive Replacement: 手順 7、 3の画像 3
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: 手順 8、 2の画像 1 Dell Inspiron N5050 Hard Drive Replacement: 手順 8、 2の画像 2
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: 手順 9、 1の画像 1
    • Slide the hard drive right and up to remove it from the laptop.
終わりに
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kristy Mayo
メンバー登録日: 09/15/16
1,394 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team 1-3, Campbell Fall 2016 University of North Texas, Team 1-3, Campbell Fall 2016人のメンバー
UNT-CAMPBELL-F16S1G3
2 メンバー
3のガイドは作成済み
4 件のコメント
Thanks again. This guide was made straightforward and clear.
jason acn - 返信
Thanks you - The clear instructions make this guide easy to follow.
Jay - 返信
wouldnt turn on after i re-assembled it
Taemon Coolz - 返信
Sehr gute Arbeit
pouchman - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 51
今までの合計 6,773
