メインコンテンツにスキップ
Dell Inspiron N5030 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: 手順 1、 1の画像 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron N5030 Display Assembly Replacement, Open the Display: 手順 2、 1の画像 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Cable: 手順 3、 1の画像 1
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Display Cable: 手順 4、 1の画像 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: 手順 5、 1の画像 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron N5030 Display Assembly Replacement, Remove the Display Assembly: 手順 6、 1の画像 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron N5030 Display Assembly Replacement, Placing the Display Assembly: 手順 7、 1の画像 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron N5030 Display Assembly Replacement, Routing the Display Cable: 手順 8、 1の画像 1
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron N5030 Display Assembly Replacement, Routing the Antenna Cable: 手順 9、 1の画像 1
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron N5030 Display Assembly Replacement, Replace the Screws: 手順 10、 1の画像 1
    • Turn the computer over and replace the two screws at the base of the computer.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,243 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
42 メンバー
1,989のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 399
