メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron N5030 Disc Drive Replacement
必要な工具と部品
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron N5030 Disc Drive Replacement, Battery: 手順 1、 2の画像 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Disc Drive Replacement: 手順 2、 2の画像 1 Dell Inspiron N5030 Disc Drive Replacement: 手順 2、 2の画像 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: 手順 3、 1の画像 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Disc Drive Replacement: 手順 4、 1の画像 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Disc Drive Replacement: 手順 5、 1の画像 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Disc Drive Replacement: 手順 6、 1の画像 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Disc Drive Replacement: 手順 7、 1の画像 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Disc Drive Replacement: 手順 8、 1の画像 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Disc Drive Replacement: 手順 9、 1の画像 1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: 手順 10、 1の画像 1
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
  11. Dell Inspiron N5030 Disc Drive Replacement: 手順 11、 1の画像 1
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Charles
メンバー登録日: 04/22/14
582 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G59
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 34
今までの合計 2,269
