はじめに
In this guide, we will be showing you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
Align the notch in the NEW memory module with the tab in the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
ある他の人がこのガイドを完成しました。
コメント 1 件
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
