はじめに
Replacing the Hard Drive for a laptop can speed it up and add more storage. Keep in mind that after replacing the hard drive you must reinstall your Operating System. Locate all product keys needed before performing this guide.
必要な工具と部品
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
Unplug the speaker connector from the motherboard.
Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
5 の人々がこのガイドを完成させました。
6 件のコメント
I hope somebody at Dell lost their job over this design.
hahaha i agree
Robert G -
The N4010 is definitely a beautiful-looking set, but it’s sure a tough nut to crack when it’s time to repair something inside it, lol :-D
A bunch of screws not listed have to be removed also they are in proximity of the cmos battery I imagine someone will damage their machine following this NOT GOOD! I signed up just to post this! Look for screws with the LETTER B they need removing before the board can come out! ifixit should screen their submissions better
In step 20 we remove the screws
