メインコンテンツにスキップ
Dell Inspiron Mini 1012 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Battery: 手順 1、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Battery: 手順 1、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Battery: 手順 1、 3の画像 3
    • Step 1 — Hard Drive Turn the device over so that the back (white side) of the device is facing up. Remove battery from laptop by pushing the two tabs outward and pull the battery outward. The tabs are highlighted in blue. Place the battery off to the side. .
    • New line.
  2. Dell Inspiron Mini 1012 Hard Drive Replacement, Remove back screws: 手順 2、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove back screws: 手順 2、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove back screws: 手順 2、 3の画像 3
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screw driver with largest phillips head in the box. Make sure to keep the screws separated by step to ensure that they can be put back in the correct location when reversing the steps.
  3. Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Keyboard: 手順 3、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Keyboard: 手順 3、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Keyboard: 手順 3、 3の画像 3
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case, using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Hard drive: 手順 4、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Hard drive: 手順 4、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement, Remove Hard drive: 手順 4、 3の画像 3
    • Remove the 2 Phillips head screws securing hard drive to case. Use the same screw driver bit as before
    • Pull the plastic tab connected to the hard drive outward in the left hand direction to remove hard drive from case.
    • When putting the hard drive back slide it in to the space so that the screw holes line up and press down until there is a snug fit.
  5. Dell Inspiron Mini 1012 Hard Drive Replacement, Add new hard drive: 手順 5、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Add new hard drive: 手順 5、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement, Add new hard drive: 手順 5、 3の画像 3
    • Add a new hard drive
  6. Dell Inspiron Mini 1012 Hard Drive Replacement, Apply back the keyboard: 手順 6、 1の画像 1
    • Insert the ribbon for keyboard back into the motherboard.
    • Than snap keyboard back into place
  7. Dell Inspiron Mini 1012 Hard Drive Replacement: 手順 7、 3の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement: 手順 7、 3の画像 2 Dell Inspiron Mini 1012 Hard Drive Replacement: 手順 7、 3の画像 3
    • Flip over the laptop
    • Put the screws back in laptop
  8. Dell Inspiron Mini 1012 Hard Drive Replacement, Put the Battery: 手順 8、 2の画像 1 Dell Inspiron Mini 1012 Hard Drive Replacement, Put the Battery: 手順 8、 2の画像 2
    • Place the battery and lock it into place
    • thanks for following this repair
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
kempc8
メンバー登録日: 11/22/13
899 ポイント
7のガイドは作成済み
チーム
K and K Fixit K and K Fixit人のメンバー
Business
1 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 29
今までの合計 2,255
