必要な工具と部品
Turn the device over so that the back (white side) of the device is facing up.
Remove battery from laptop by pushing the two tabs outward and pull the battery outward. The tabs are highlighted in blue. Place the battery off to the side.
Remove the 3 screws highlighted in red that secure the keyboard to the case using the screw driver with largest phillips head in the box.
Make sure to keep the screws separated by step to ensure that they can be put back in the correct location when reversing the steps.
16 の人々がこのガイドを完成させました。
4 件のコメント
Its a standard 2.5" SATA and yes you can replace it with a SSD from any local computer store or even Best Buy.
I bought a Kingston SSD to upgrade mine, but cloning the old hard drive or even trying to install the SSD cleanly doesn’t work, Windows says it wont install and it doesn’t boot. The BIOS isn’t very helpful either.
This guide should not be rated moderate because everything is straight forward. The trickiest step was removing the keyboard. Once it is disassembled to the point of replacing the hard drive, you can also replace pretty much everything else also.
