1. Remove the battery
    • Remove the battery
  2. Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  5. Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
ゴール
4 の人々がこのガイドを完成させました。
Marie K Bordley
メンバー登録日: 2014年09月30日
223 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-1, Buehl Fall 2014 Ohio State, Team 1-1, Buehl Fall 2014人のメンバー
OSU-BUEHL-F14S1G1
4 メンバー
2のガイドは作成済み
コメント1件
After keyboard open, You can change HDD or Memory as you like.
최희욱 - 返信
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 2,683
