はじめに
This guide will give step-by-step instructions on how to replace the memory card in your device.
必要な工具と部品
On the bottom of the laptop locate the removable panel and screw holding it to the body. Loosen the screw and take the cover off.
この手順で使用する道具:Tweezers$4.99
Remove the black and white antenna cable from the wifi adapter by pinching the gold contacts with the tips of your finger, or you can use tweezers, and pull them straight away from the adapter.
Unscrew the single 5mm Phillips 0 screw on the top right of the adapter. The adapter should start to angle away from the body of the computer. Once the screw is off completely, pull the adapter out of the data slot.
Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
Remove the following:
Two 4mm Phillips screws securing the motherboard
AC adapter cable
USB and SIM card cable connector
Display cable connector
Carefully lift the motherboard out.
3 の人々がこのガイドを完成させました。
3件のガイドコメント
It is possible to upgrade the memory by simply (!) cutting aq hole in the bottom of the computer case. I used the pictures and Vulcan logic to determine the location and dimensions of the required hole. I used a vibrating saw to cut the hole. You need to be careful not to cut too deep. Once you have a square panel cut out, you need to snip through the copper shield covering the memory card. Then it is a simple in and out replacement. I used a leftover 2 Gig memory card from my MacBook Pro.
Mucheasier than taking out all those screws and connectors!
Here’s an easier-but riskier- technique. Cut a rectangular hole in the bottom of your Mini 10V. I did it and it worked. Needles to say, you must be careful not to cut too deep! Measure in from the left side (computer shut, upside down and the empty battery compartment away from you) 3/4 inch, and 4.5 inch (from the edge. the lines you draw will be 3.75 inches apart. measure up from the keyboard edge 2.5 inches and 4.75 inches and draw horizontal lines. The ‘box’ you drew is your cutting template. Once inside you need to cut a copper shield to get to the memory card. From that point on it’s easy. I used the 2 gig memory card from my MacBook Pro. When you’re done, glue the panel you cut out back in place and reinsert battery and you’re ready to go. (For cutting the hole, I used a vibrating multi tool with a saw blade)
Disclaimer: Your mileage may vary. If you brick your Mini 10V, you can buy another on Ebay for ~$75.
Good Luck.
Excellent step-by-step graphical explanation makes it look easy by following the instructions congratulations.
