メインコンテンツにスキップ
Dell Inspiron Mini 10 Palm Rest Bracket Replacement
必要な工具と部品
  1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: 手順 1、 1の画像 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 4、 1の画像 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 5、 2の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 5、 2の画像 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 6、 2の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 6、 2の画像 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  7. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: 手順 7、 1の画像 1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  8. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 8、 2の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 8、 2の画像 2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  9. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 9、 2の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 9、 2の画像 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  10. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 10、 2の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 10、 2の画像 2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  11. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 11、 3の画像 1 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 11、 3の画像 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 11、 3の画像 3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  12. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 手順 12、 1の画像 1
    • Gently pry off the bracket using the prying tool.
終わりに
作成者
4人の作成者と共同で作成されました。
Danielle Jarecki
メンバー登録日: 10/21/16
334 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016人のメンバー
UWT-ROSE-F16S1G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 300
