メインコンテンツにスキップ
Dell Inspiron Mini 10 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: 手順 3、 1の画像 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 4、 1の画像 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 6、 1の画像 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 7、 2の画像 1 Dell Inspiron Mini 10 Hard Drive Replacement: 手順 7、 2の画像 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 8、 2の画像 1 Dell Inspiron Mini 10 Hard Drive Replacement: 手順 8、 2の画像 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 1 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 2
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
  10. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 10、 2の画像 1 Dell Inspiron Mini 10 Hard Drive Replacement: 手順 10、 2の画像 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
  11. Dell Inspiron Mini 10 Hard Drive Replacement: 手順 11、 1の画像 1
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Bariso Shuba
メンバー登録日: 10/26/16
270 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016人のメンバー
UWT-ROSE-F16S1G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 7,561
