メインコンテンツにスキップ
Dell Inspiron M5110 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron M5110 Display Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Display Assembly Replacement: 手順 2、 1の画像 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Display Assembly Replacement: 手順 3、 1の画像 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Display Assembly Replacement, Keyboard: 手順 4、 1の画像 1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Display Assembly Replacement: 手順 5、 1の画像 1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Display Assembly Replacement: 手順 6、 1の画像 1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Display Assembly Replacement: 手順 7、 1の画像 1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Display Assembly Replacement: 手順 8、 1の画像 1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Display Assembly Replacement: 手順 9、 1の画像 1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Display Assembly Replacement, Palmrest: 手順 10、 1の画像 1
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Display Assembly Replacement: 手順 11、 1の画像 1
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Display Assembly Replacement: 手順 12、 2の画像 1 Dell Inspiron M5110 Display Assembly Replacement: 手順 12、 2の画像 2
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Display Assembly Replacement: 手順 13、 2の画像 1 Dell Inspiron M5110 Display Assembly Replacement: 手順 13、 2の画像 2
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
  14. Dell Inspiron M5110 Display Assembly Replacement, Display Assembly: 手順 14、 1の画像 1
    • Turn the device over and then remove the two 5 mm Phillips #0 screws that keeps the display assembly to the base and then flip the device.
  15. Dell Inspiron M5110 Display Assembly Replacement: 手順 15、 1の画像 1
    • Disconnect the display antenna cable from the Mini Card.
  16. Dell Inspiron M5110 Display Assembly Replacement: 手順 16、 1の画像 1
    • Disconnect the LCD display cable and touch screen cable.
  17. Dell Inspiron M5110 Display Assembly Replacement: 手順 17、 2の画像 1 Dell Inspiron M5110 Display Assembly Replacement: 手順 17、 2の画像 2
    • There are two 5 mm Phillips # 0 screws on each hinge.
    • Unscrew the four 5 mm Phillips # 0 screws holding the hinge that keeps the monitor in place.
  18. Dell Inspiron M5110 Display Assembly Replacement: 手順 18、 1の画像 1
    • Lift the display off the computer base.
終わりに
作成者
3人の作成者と共同で作成されました。
Maxwell Dumerant
メンバー登録日: 10/18/16
19 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G3
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 282
