メインコンテンツにスキップ
Dell Inspiron M5010 SD Card Slot Replacement
必要な工具と部品
  1. Dell Inspiron M5010 SD Card Slot Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron M5010 SD Card Slot Replacement, Battery: 手順 1、 2の画像 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 SD Card Slot Replacement, Remove keyboard retaining screw: 手順 2、 1の画像 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 SD Card Slot Replacement: 手順 3、 3の画像 1 Dell Inspiron M5010 SD Card Slot Replacement: 手順 3、 3の画像 2 Dell Inspiron M5010 SD Card Slot Replacement: 手順 3、 3の画像 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 SD Card Slot Replacement: 手順 4、 1の画像 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 SD Card Slot Replacement: 手順 5、 1の画像 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 SD Card Slot Replacement, Palm Rest: 手順 6、 1の画像 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 SD Card Slot Replacement: 手順 7、 2の画像 1 Dell Inspiron M5010 SD Card Slot Replacement: 手順 7、 2の画像 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 SD Card Slot Replacement: 手順 8、 1の画像 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 SD Card Slot Replacement: 手順 9、 3の画像 1 Dell Inspiron M5010 SD Card Slot Replacement: 手順 9、 3の画像 2 Dell Inspiron M5010 SD Card Slot Replacement: 手順 9、 3の画像 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 手順 10、 3の画像 1 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 手順 10、 3の画像 2 Dell Inspiron M5010 SD Card Slot Replacement, SD Card Slot: 手順 10、 3の画像 3
    • Unplug the SD Card Slot cable.
    • Gently lift the SD Card Slot from the computer.
終わりに
作成者
3人の作成者と共同で作成されました。
April Poucher
メンバー登録日: 10/13/14
1,164 ポイント
10のガイドは作成済み
チーム
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G5
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 416
