パーツ
パーツは必要ありません。
  1. Make sure laptop is powered off before  removing the battery. Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Using the Phillips #000 screwdriver, loosen the screw holding in the back cover. Then, lift up the back cover to remove it.
    • Using the Phillips #000 screwdriver, loosen the screw holding in the back cover.
    • Then, lift up the back cover to remove it.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Snap open the top memory clips and remove the memory drive they hold in. Snap open the top memory clips and remove the memory drive they hold in. Snap open the top memory clips and remove the memory drive they hold in.
    • Snap open the top memory clips and remove the memory drive they hold in.
  5. Snap open the bottom memory clips and remove the memory drive they hold in. Snap open the bottom memory clips and remove the memory drive they hold in. Snap open the bottom memory clips and remove the memory drive they hold in.
    • Snap open the bottom memory clips and remove the memory drive they hold in.
  6. The laptop computer should look like this once both memory cards are removed.
    • The laptop computer should look like this once both memory cards are removed.
まとめ
April Poucher
メンバー登録日: 2014年10月13日
1,152 ポイント
10のガイドは作成済み
チーム
Clemson, Team 1-5, Benson Fall 2014 Clemson, Team 1-5, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G5
4 メンバー
11のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 226
