メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Before any work can be done ensure that the laptop is powered off.
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Locate the battery release switch on the bottom of the laptop.
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Remove the back panel: Use the screwdriver to remove the screws on the back panel. Lift the back panel off the laptop to expose the interior of the laptop. Locate the hard drive.
    • Remove the back panel: Use the screwdriver to remove the screws on the back panel.
    • Lift the back panel off the laptop to expose the interior of the laptop.
    • Locate the hard drive.
  6. Remove the current hard drive.
    • Remove the current hard drive.
    • Look at the model number and order the replacement if needed.
    • Insert the new hard drive in.
終わりに
Anthony Toscano
メンバー登録日: 2016年10月20日
323 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-7, Martin Fall 2016 UMass Dartmouth, Team 6-7, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S6G7
3 メンバー
4のガイドは作成済み
2 件のコメント
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
George A. - 返信
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
oldturkey03 -
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 482
