メインコンテンツにスキップ
Dell Inspiron E1405 LCD Screen Replacement
必要な工具と部品
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: 手順 2、 3の画像 1 Dell Inspiron E1405 LCD Screen Replacement: 手順 2、 3の画像 2 Dell Inspiron E1405 LCD Screen Replacement: 手順 2、 3の画像 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 1 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 2 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: 手順 4、 1の画像 1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: 手順 5、 3の画像 1 Dell Inspiron E1405 LCD Screen Replacement: 手順 5、 3の画像 2 Dell Inspiron E1405 LCD Screen Replacement: 手順 5、 3の画像 3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: 手順 6、 2の画像 1 Dell Inspiron E1405 LCD Screen Replacement: 手順 6、 2の画像 2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: 手順 7、 2の画像 1 Dell Inspiron E1405 LCD Screen Replacement: 手順 7、 2の画像 2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Sarah Neal Secrest
メンバー登録日: 03/20/17
597 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team S8-G3, Bennett Spring 2017 Texas Tech, Team S8-G3, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G3
3 メンバー
5のガイドは作成済み
コメント 1 件
I need complete body *Dell INSPIRON E1405 .
St Master Fun - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 465
