メインコンテンツにスキップ
Dell Inspiron B130 Screen Replacement
必要な工具と部品
  1. Dell Inspiron B130 Screen Replacement, Battery: 手順 1、 3の画像 1 Dell Inspiron B130 Screen Replacement, Battery: 手順 1、 3の画像 2 Dell Inspiron B130 Screen Replacement, Battery: 手順 1、 3の画像 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Screen Replacement: 手順 2、 3の画像 1 Dell Inspiron B130 Screen Replacement: 手順 2、 3の画像 2 Dell Inspiron B130 Screen Replacement: 手順 2、 3の画像 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Screen Replacement: 手順 3、 3の画像 1 Dell Inspiron B130 Screen Replacement: 手順 3、 3の画像 2 Dell Inspiron B130 Screen Replacement: 手順 3、 3の画像 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Screen Replacement, Keyboard: 手順 4、 1の画像 1
    • Put down the computer and open up the screen.
    • There is a long piece of plastic underneath the screen that you will have to remove.
  5. Dell Inspiron B130 Screen Replacement: 手順 5、 3の画像 1 Dell Inspiron B130 Screen Replacement: 手順 5、 3の画像 2 Dell Inspiron B130 Screen Replacement: 手順 5、 3の画像 3
    • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
    • Insert the plastic opening tool into the little slot.
    • Lift up gently and remove the plastic cover.
  6. Dell Inspiron B130 Screen Replacement: 手順 6、 1の画像 1
    • Remove the two 4mm screws at the top of the keyboard.
    • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
  7. Dell Inspiron B130 Screen Replacement: 手順 7、 2の画像 1 Dell Inspiron B130 Screen Replacement: 手順 7、 2の画像 2
    • Lift keyboard up slightly and you will see the keyboard connection.
    • This black tab has to be lifted up to remove the keyboard.
    • Put your finger underneath the tab and pull back gently as indicated.
    • You can now remove the keyboard.
  8. Dell Inspiron B130 Screen Replacement, Screen: 手順 8、 3の画像 1 Dell Inspiron B130 Screen Replacement, Screen: 手順 8、 3の画像 2 Dell Inspiron B130 Screen Replacement, Screen: 手順 8、 3の画像 3
    • This reveals two connections that must be removed.
    • Remove the one with the blue tape by lifting up on the tape gently.
  9. Dell Inspiron B130 Screen Replacement: 手順 9、 2の画像 1 Dell Inspiron B130 Screen Replacement: 手順 9、 2の画像 2
    • Remove the other connection by pulling apart gently.
  10. Dell Inspiron B130 Screen Replacement: 手順 10、 1の画像 1
    • Remove the two 6mm screws that are directly under the screen.
  11. Dell Inspiron B130 Screen Replacement: 手順 11、 2の画像 1 Dell Inspiron B130 Screen Replacement: 手順 11、 2の画像 2
    • Close the computer and flip it over so that the back is facing up.
    • Remove the two 6mm screws that are behind each of the screens pivot points.
    • Open up the screen and now it can be lifted up and off of the computer.
終わりに
作成者
2人の作成者と共同で作成されました。
Patrick McNeil
メンバー登録日: 10/19/16
937 ポイント
8のガイドは作成済み
チーム
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G8
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 18
今までの合計 375
