メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Dell Inspiron 9300 Trackpad Replacement
必要な工具と部品
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: 手順 1、 1の画像 1
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: 手順 2、 1の画像 1
    • Remove the twelve 6mm Phillips case screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: 手順 3、 1の画像 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: 手順 4、 3の画像 1 Dell Inspiron 9300 Trackpad Replacement: 手順 4、 3の画像 2 Dell Inspiron 9300 Trackpad Replacement: 手順 4、 3の画像 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard
  5. Dell Inspiron 9300 Trackpad Replacement: 手順 5、 2の画像 1 Dell Inspiron 9300 Trackpad Replacement: 手順 5、 2の画像 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: 手順 6、 2の画像 1 Dell Inspiron 9300 Trackpad Replacement: 手順 6、 2の画像 2
    • Remove the seven 6mm Phillips scres holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger
  7. Dell Inspiron 9300 Trackpad Replacement: 手順 7、 2の画像 1 Dell Inspiron 9300 Trackpad Replacement: 手順 7、 2の画像 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger
    • Remove the trackpad ribbon cable from the motherboard using a spudger
  8. Dell Inspiron 9300 Trackpad Replacement: 手順 8、 1の画像 1
    • Pull up and away on the uppercase to remove.
終わりに
作成者
2人の作成者と共同で作成されました。
Steven Faulkner
メンバー登録日: 09/26/16
214 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G6
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 165
