メインコンテンツにスキップ
Dell Inspiron 9300 Speaker System Replacement
必要な工具と部品
  1. Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: 手順 1、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: 手順 1、 2の画像 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Speaker System Replacement: 手順 2、 1の画像 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Speaker System Replacement: 手順 3、 3の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 3、 3の画像 2 Dell Inspiron 9300 Speaker System Replacement: 手順 3、 3の画像 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Speaker System Replacement: 手順 4、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 4、 2の画像 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Speaker System Replacement: 手順 5、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 5、 2の画像 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Speaker System Replacement: 手順 6、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 6、 2の画像 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Speaker System Replacement: 手順 7、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 7、 2の画像 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Speaker System Replacement, Speaker System: 手順 8、 1の画像 1
    • Remove the two 3mm Phillips screws holding the CD-ROM drive in place.
    • Slide the CD-ROM drive out of the lower case.
  9. Dell Inspiron 9300 Speaker System Replacement: 手順 9、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 9、 2の画像 2
    • Use a spudger to disconnect the subwoofer cable.
    • Repeat for the adjacent speaker connector.
  10. Dell Inspiron 9300 Speaker System Replacement: 手順 10、 1の画像 1
    • Pry away the black tape that holds the sound system wires in place.
  11. Dell Inspiron 9300 Speaker System Replacement: 手順 11、 2の画像 1 Dell Inspiron 9300 Speaker System Replacement: 手順 11、 2の画像 2
    • Remove the 7mm Phillips screws that hold the subwoofer in place.
    • Remove the four (two for each speaker) 5mm Phillips screws that secure the left and right speakers.
終わりに
作成者
5人の作成者と共同で作成されました。
Steven Faulkner
メンバー登録日: 11/10/16
490 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G6
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 242
