Lift up the keyboard using your fingers or a plastic opening tool.
Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
Disconnect the cable by sliding the connector ears outward.
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Be careful to not tear the ribbon cables hidden behind the panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
depending on your model, there could still be some hidden screws on the bottom of the case of the mini that hold the palm-rest in place
Remove the covers from the panel
Remove the buttons from the panel
Release the mouse button by flipping the center connector tab up
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
