はじめに
This guide will teach you how to remove the buttons below the track pad from the laptop device.
必要なもの
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
ある他の人がこのガイドを完成しました。
