1. Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Push the release tabs toward the center of the device.
    • Remove the battery.
  2. Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Battery removal is not necessary for keyboard removal.
  3. Lift up the keyboard using your fingers or a plastic opening tool
    • Lift up the keyboard using your fingers or a plastic opening tool
    • Do not not tear the ribbon cable hidden behind the keyboard
    • Disconnect the cable by sliding the connector ears outward
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  6. Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
    • Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
  7. There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • NOTE: Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  8. There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
    • There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
まとめ
3 の人々がこのガイドを完成させました。
Kyle Beekman
メンバー登録日: 2012年04月05日
144 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S14G10
5 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,233
