この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the LCD screen is not working, it may be a problem with the video card.
必要な工具と部品
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
After removing the keyboard, locate and remove the labeled screws.
Gently lift the Video Card unit for replacing.
3 の人々がこのガイドを完成させました。
