メインコンテンツにスキップ
Dell Inspiron 8600 Top Case Replacement
必要な工具と部品
  1. Dell Inspiron 8600 Top Case Replacement, Battery: 手順 1、 1の画像 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Top Case Replacement, Power Button: 手順 2、 3の画像 1 Dell Inspiron 8600 Top Case Replacement, Power Button: 手順 2、 3の画像 2 Dell Inspiron 8600 Top Case Replacement, Power Button: 手順 2、 3の画像 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Top Case Replacement: 手順 3、 1の画像 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Dell Inspiron 8600 Top Case Replacement, Display Module: 手順 4、 2の画像 1 Dell Inspiron 8600 Top Case Replacement, Display Module: 手順 4、 2の画像 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Top Case Replacement: 手順 5、 1の画像 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Top Case Replacement: 手順 6、 2の画像 1 Dell Inspiron 8600 Top Case Replacement: 手順 6、 2の画像 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Top Case Replacement: 手順 7、 1の画像 1
    • Now remove the display module.
  8. Dell Inspiron 8600 Top Case Replacement, Top Case: 手順 8、 3の画像 1 Dell Inspiron 8600 Top Case Replacement, Top Case: 手順 8、 3の画像 2 Dell Inspiron 8600 Top Case Replacement, Top Case: 手順 8、 3の画像 3
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  9. Dell Inspiron 8600 Top Case Replacement: 手順 9、 3の画像 1 Dell Inspiron 8600 Top Case Replacement: 手順 9、 3の画像 2 Dell Inspiron 8600 Top Case Replacement: 手順 9、 3の画像 3
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  10. Dell Inspiron 8600 Top Case Replacement: 手順 10、 1の画像 1
    • LCD should remove smoothly.
    • The top case will be what remains.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Perry
メンバー登録日: 04/12/11
251 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G22
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 21
今までの合計 2,223
