メインコンテンツにスキップ
はじめに
Follow this guide to remove the LCD Display.
パーツ
パーツは指定されていません。
  1. Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off. Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover. Be careful of wire attached to underside of the hinge cover.
    • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
    • Be careful of wire attached to underside of the hinge cover.
  2. Pull the small black tab on the right hand side of the laptop.
    • Pull the small black tab on the right hand side of the laptop.
    • The hinge cover has now been removed.
  3. Flip the laptop over and remove the indicated screws. Flip the laptop back over.
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Disconnect the video card from the display module by gently lifting upwards on the black tab.
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. Lift the display module directly upwards from the base of the computer. Lift the display module directly upwards from the base of the computer.
    • Lift the display module directly upwards from the base of the computer.
  7. The display module has been removed.
    • The display module has been removed.
  8. First, remove the plastic tabs that are covering the interior screws. After removing the tabs, remove the interior screws using a #1 Philips Screwdriver. Note there are 8 tabs and 8 screws in total.
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  9. Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  10. Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  11. Remove the broken LCD unit, and replace with new unit.
    • Remove the broken LCD unit, and replace with new unit.
まとめ
2 の人々がこのガイドを完成させました。
Perry
メンバー登録日: 2011年04月12日
248 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G22
4 メンバー
16のガイドは作成済み
コメント1件
which controller board do i have to use for this model ?
bcdoor - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,386
