この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you are having difficulties with the keyboard, please follow this guide.
必要な工具と部品
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Remove the screws at the top of the keyboard as indicated indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
2 の人々がこのガイドを完成させました。
コメント 1 件
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 返信
