はじめに
This guide shows you how to remove the cooling fan in your Dell Inspiration 8600. The cooling fan regulates the computer's temperature. First you must remove the hinge cover and keyboard lower case to finally have access to the cooling fan.
必要な工具と部品
Remove both screws from the fan using a Philips head screwdriver.
Slide off the cooling fan.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
