メインコンテンツにスキップ
Dell Inspiron 7573 2-in-1 Hard Drive Replacement
必要な工具と部品
  1. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 2、 3の画像 1 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 2、 3の画像 2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 2、 3の画像 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 4、 3の画像 1 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 4、 3の画像 2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 4、 3の画像 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 1 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: 手順 5、 3の画像 3
    • Using the pull-tab, disconnect the hard drive cable from the motherboard.
    • In a laptop containing a hard drive, the other end of the cable will be seated in the hard drive under the silver cover. The device used in this guide was lacking one, so the cable appears loose.
  6. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the three 3 mm screws that secure the hard-drive assembly using a Phillips #00 screwdriver.
  7. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 7、 1の画像 1
    • Disconnect the hard drive cable from the hard drive.
  8. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 8、 2の画像 1 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 8、 2の画像 2
    • Lift the right speaker by releasing the rubber grommets from the slots on the palm-rest assembly.
  9. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 9、 1の画像 1
    • Remove the four 3 mm screws that secure the hard drive bracket to the hard drive with a Phillips #00 screwdriver.
  10. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: 手順 10、 1の画像 1
    • Lift up the hard drive and replace it.
終わりに
作成者
2人の作成者と共同で作成されました。
Kylie Freese
メンバー登録日: 09/27/21
405 ポイント
3のガイドは作成済み
チーム
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021人のメンバー
CASC-LAREAU-F21S1G2
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 19
今までの合計 989
