メインコンテンツにスキップ
Dell Inspiron 700m RAM Replacement
必要な工具と部品
  1. Dell Inspiron 700m RAM Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin, make sure the 700m is powered off.
    • Unplug the power cable.
    • Flip the 700m over and remove the battery.
    • Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
  2. Dell Inspiron 700m RAM Replacement, Outer RAM Cover: 手順 2、 1の画像 1
    • Remove the two Phillips screws securing the RAM cover.
    • Remove the RAM cover and set it aside.
  3. Dell Inspiron 700m RAM Replacement, RAM Module #1: 手順 3、 3の画像 1 Dell Inspiron 700m RAM Replacement, RAM Module #1: 手順 3、 3の画像 2 Dell Inspiron 700m RAM Replacement, RAM Module #1: 手順 3、 3の画像 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, slide it in place at about the same angle until it is snug, and then swing it downward until the two clips snap into place.
  4. Dell Inspiron 700m RAM Replacement: 手順 4、 3の画像 1 Dell Inspiron 700m RAM Replacement: 手順 4、 3の画像 2 Dell Inspiron 700m RAM Replacement: 手順 4、 3の画像 3
    • Flip the 700m over and swing the screen all the way open until it lays flat.
    • Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim.
  5. Dell Inspiron 700m RAM Replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the two Phillips screws securing the keyboard.
  6. Dell Inspiron 700m RAM Replacement: 手順 6、 1の画像 1
    • Tilt the top of the keyboard up at an angle, and gently push the keyboard toward the back of the 700m, freeing the tabs along the bottom.
    • Do not push very hard, or you may damage the keyboard ribbon cable.
  7. Dell Inspiron 700m RAM Replacement: 手順 7、 3の画像 1 Dell Inspiron 700m RAM Replacement: 手順 7、 3の画像 2 Dell Inspiron 700m RAM Replacement: 手順 7、 3の画像 3
    • Tilt the bottom of the keyboard up at an angle.
    • Use the pointed end of a spudger to disconnect the keyboard ribbon cable by pushing open the clips on either side.
    • Remove the keyboard and set it aside.
  8. Dell Inspiron 700m RAM Replacement, Inner RAM Cover: 手順 8、 2の画像 1 Dell Inspiron 700m RAM Replacement, Inner RAM Cover: 手順 8、 2の画像 2
    • Remove the two Phillips screws securing the inner RAM cover.
    • Tilt the right side of the RAM cover up at an angle and pull it free.
  9. Dell Inspiron 700m RAM Replacement, RAM Module #2: 手順 9、 2の画像 1 Dell Inspiron 700m RAM Replacement, RAM Module #2: 手順 9、 2の画像 2
終わりに
4 の人々がこのガイドを完成させました。
Jeff Suovanen
メンバー登録日: 08/06/13
427,043 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
16,573のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 3,561
