Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
Flip the LCD panel over.
Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
Remove the cable by squeezing each side of the connector and gently pulling straight out.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
