はじめに
This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
- Battery
- Hard Drive
- DC Jack
- Keyboard
必要な工具と部品
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
When you have removed the LCD bezel, place it to the side.
2 の人々がこのガイドを完成させました。
