はじめに
Replacing the RAM is simple, push down a snap to unlock it, pull it out then push the new one into place.
必要な工具と部品
The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
Pull up on the RAM chip to remove it.
ある他の人がこのガイドを完成しました。
