メインコンテンツにスキップ
Dell Inspiron 5100 PP07L CD Drive Replacement
必要な工具と部品
  1. Dell Inspiron 5100 PP07L CD Drive Replacement, Keyboard: 手順 1、 1の画像 1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 2、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 2、 2の画像 2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 3、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 3、 2の画像 2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 4、 1の画像 1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 手順 5、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 手順 5、 2の画像 2
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 6、 1の画像 1
    • Detach the screen connector.
  7. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 7、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 7、 2の画像 2
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 8、 1の画像 1
    • Lift and remove display screen.
  9. Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 手順 9、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 手順 9、 2の画像 2
    • Flip to the back side of the laptop.
    • Remove thirteen screws (8.6mm).
    • If battery has not yet been removed, remove it now and remove single silver-colored screw at top of empty battery bay.
  10. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 10、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 10、 2の画像 2
    • Remove one screw (8.6 mm) on metal plating.
    • Remove the metal plating.
  11. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 11、 1の画像 1
    • Remove two screws (5.8mm)
  12. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 12、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 12、 2の画像 2
    • Disconnect cable.
  13. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 13、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 13、 2の画像 2
    • Make sure that single silver-colored screw has been removed from empty battery bay
    • Remove top cover by lifting the edges upward.
  14. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 14、 2の画像 1 Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 14、 2の画像 2
    • Remove CD drive plating screw (5.8mm)
  15. Dell Inspiron 5100 PP07L CD Drive Replacement: 手順 15、 1の画像 1
    • Slide outwards to remove
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
May Chauvin
メンバー登録日: 04/14/11
201 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G34
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 4,429
