メインコンテンツにスキップ
Dell Inspiron 5100 (2015) Thermal Paste Replacement
必要な工具と部品
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 手順 1、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 手順 1、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 手順 1、 3の画像 3
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 2、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 2、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 2、 3の画像 3
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 3、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 3、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 3、 3の画像 3
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 4、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 4、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 4、 3の画像 3
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 5、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 5、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 5、 3の画像 3
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 6、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 6、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 6、 3の画像 3
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 7、 3の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 7、 3の画像 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 7、 3の画像 3
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 8、 2の画像 1 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 手順 8、 2の画像 2
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Dominic Treadwell
メンバー登録日: 07/09/23
184 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-8, Meigs Summer 2023 Austin Community College, Team 1-8, Meigs Summer 2023人のメンバー
AUSTINCC-MEIGS-SU23S1G8
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 26
今までの合計 205
