メインコンテンツにスキップ
Dell Inspiron 3847 RAM Stick Replacement
必要な工具と部品
  1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: 手順 1、 1の画像 1
    • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
    • Unplug the power cable and remove any and all peripherals connected to PC.
  2. Dell Inspiron 3847 RAM Stick Replacement: 手順 2、 3の画像 1 Dell Inspiron 3847 RAM Stick Replacement: 手順 2、 3の画像 2 Dell Inspiron 3847 RAM Stick Replacement: 手順 2、 3の画像 3
    • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
    • Remove the two Phillips #0 screws from the back side of panel.
    • Slide the side panel off completely.
  3. Dell Inspiron 3847 RAM Stick Replacement: 手順 3、 2の画像 1 Dell Inspiron 3847 RAM Stick Replacement: 手順 3、 2の画像 2
    • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
    • Repeat this step for each stick of RAM.
    • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
  4. Dell Inspiron 3847 RAM Stick Replacement: 手順 4、 3の画像 1 Dell Inspiron 3847 RAM Stick Replacement: 手順 4、 3の画像 2 Dell Inspiron 3847 RAM Stick Replacement: 手順 4、 3の画像 3
    • Align the new memory sticks with the memory slots.
    • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
    • Repeat this step for each stick of RAM you want to install.
  5. Dell Inspiron 3847 RAM Stick Replacement: 手順 5、 3の画像 1 Dell Inspiron 3847 RAM Stick Replacement: 手順 5、 3の画像 2 Dell Inspiron 3847 RAM Stick Replacement: 手順 5、 3の画像 3
    • Slide the side panel back into position and screw in with the same screws from Step #2.
    • Plug all peripherals into the PC and switch it back on.
    • Boot up the computer. If no errors appear, then installation is complete!
終わりに
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
作成者
2人の作成者と共同で作成されました。
Maninder
メンバー登録日: 05/11/20
171 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G24, O'Regan Summer 2020 York University, Team S1-G24, O'Regan Summer 2020人のメンバー
YORK-O'REGAN-SU20S1G24
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 37
今までの合計 797
