メインコンテンツにスキップ
Dell Inspiron 3520 Optical Drive Replacement
必要な工具と部品
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 3520 Optical Drive Replacement, Battery: 手順 1、 2の画像 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: 手順 2、 3の画像 1 Dell Inspiron 3520 Optical Drive Replacement: 手順 2、 3の画像 2 Dell Inspiron 3520 Optical Drive Replacement: 手順 2、 3の画像 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 手順 3、 2の画像 1 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 手順 3、 2の画像 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: 手順 4、 1の画像 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: 手順 5、 2の画像 1 Dell Inspiron 3520 Optical Drive Replacement: 手順 5、 2の画像 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 手順 6、 2の画像 1 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 手順 6、 2の画像 2
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: 手順 7、 2の画像 1 Dell Inspiron 3520 Optical Drive Replacement: 手順 7、 2の画像 2
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ian
メンバー登録日: 01/30/15
1,557 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S16G2
3 メンバー
5のガイドは作成済み
コメント 1 件
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 22
今までの合計 2,686
