はじめに
Is your computer experiencing problems with connecting to the Wi-Fi or the internet? Consider using this guide to replace the WLAN card in your device.
必要な工具と部品
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
ある他の人がこのガイドを完成しました。
