この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your computer constantly resetting the time and date? Consider using this guide to replace the CMOS battery in your device.
必要な工具と部品
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
Once the CMOS battery has been loosened, remove it from the device.
ある他の人がこのガイドを完成しました。
