メインコンテンツにスキップ
Dell Inspiron 3148 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 3148 Battery Replacement, Back Panel: 手順 1、 2の画像 1 Dell Inspiron 3148 Battery Replacement, Back Panel: 手順 1、 2の画像 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Battery Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Battery Replacement: 手順 3、 2の画像 1 Dell Inspiron 3148 Battery Replacement: 手順 3、 2の画像 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Battery Replacement, Battery: 手順 4、 1の画像 1
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Battery Replacement: 手順 5、 1の画像 1
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Battery Replacement: 手順 6、 1の画像 1
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Battery Replacement: 手順 7、 1の画像 1
    • Remove the battery completely.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Christopher Gravelle
メンバー登録日: 10/23/18
837 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018人のメンバー
UMASSD-SIMCOCK-F18S1G2
3 メンバー
7のガイドは作成済み
コメント 1 件
Apparently the battery screws on mine all have red thread lock on them, meaning they will not come out and I fear I may end up stripping them if I’m not careful, I got one out, which his how I know they used red thread lock. Blue would have been sufficient
Joshua Vignolo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 276
