メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Dell Inspiron 17R-N7010 Palm Rest Replacement
必要な工具と部品
  1. Dell Inspiron 17R-N7010 Palm Rest Replacement, Battery: 手順 1、 1の画像 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 2、 1の画像 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 2 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 3
    • Be sure to power off the laptop and remove the battery before proceeding with the disassembly.
    • Flip the laptop to the back. Locate and unscrew the four screws highlighted in green.
    • Flip the laptop over and open to the face of the keyboard.
    • You will notice the keyboard is connected to the laptop by a thin wire (blue). To disconnect the keyboard, lift up the latch boxed in blue holding the wire in place.
  4. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 2 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 3
    • Flip to the back of the laptop. To remove the back cover, locate and unscrew the screws
    • Next, slide the CD drive out to locate the final screws.
    • Unscrew the three screws
  5. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 5、 1の画像 1
    • This step may be tricky, and feel like you are breaking the laptop. Following these steps carefully will ensure a safe disassembly of the device without damaging the hardware.
    • To safely remove the top cover, grab a spudger and insert it under the grey surface where the blue circle is shown. Make prying motion upwards to detach the locks.
    • Work clockwise starting from the indicated circle; inserting the spudger under the grey cover, and lifting up to detach the locks.
  6. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 6、 2の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 6、 2の画像 2
    • Make sure to disconnect the wires circled in green before completely removing the top cover.
    • After removing the cover, you will now have access to the inner hardware: Mother Board, fans, processors, etc.
終わりに
作成者
9人の作成者と共同で作成されました。
Brandon Lopez
メンバー登録日: 09/21/18
319 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S8-G5, Riccardelli Fall 2018 University of North Texas, Team S8-G5, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 635
