メインコンテンツにスキップ
Dell Inspiron 17R-N7010 Palm Rest Replacement
必要な工具と部品
  1. Dell Inspiron 17R-N7010 Palm Rest Replacement, Battery: 手順 1、 1の画像 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 2、 1の画像 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 2 Dell Inspiron 17R-N7010 Palm Rest Replacement, Palm Rest: 手順 3、 3の画像 3
    • Remove the four screws from the back panel.
    • Flip the laptop over and open it to view the keyboard.
    • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
  4. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 2 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 4、 3の画像 3
    • Close the laptop and flip it over so the bottom is facing upwards.
    • Remove the two screws from the small panel.
    • Remove the small back panel.
    • Slide the CD drive out of the laptop.
    • Remove the three screws from the CD drive slot.
  5. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 5、 1の画像 1
    • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
    • Remove the top cover by inserting a spudger under the surface.
    • Working clockwise, pry upwards with the spudger to detach the clips.
  6. Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 6、 2の画像 1 Dell Inspiron 17R-N7010 Palm Rest Replacement: 手順 6、 2の画像 2
    • Disconnect the ribbon cables.
    • Remove the cover to access the inner hardware of the laptop.
終わりに
作成者
9人の作成者と共同で作成されました。
Brandon Lopez
メンバー登録日: 09/21/18
319 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S8-G5, Riccardelli Fall 2018 University of North Texas, Team S8-G5, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 665
