メインコンテンツにスキップ
Dell Inspiron 17R-5737 Screen Replacement
必要な工具と部品
  1. Dell Inspiron 17R-5737 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Screen Replacement: 手順 2、 2の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 2、 2の画像 2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Screen Replacement: 手順 3、 2の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 3、 2の画像 2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Screen Replacement, Optical Drive: 手順 4、 2の画像 1 Dell Inspiron 17R-5737 Screen Replacement, Optical Drive: 手順 4、 2の画像 2
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Screen Replacement, Access Panel: 手順 5、 1の画像 1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Screen Replacement, Hard Drive: 手順 6、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement, Hard Drive: 手順 6、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement, Hard Drive: 手順 6、 3の画像 3
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Screen Replacement, RAM: 手順 7、 2の画像 1 Dell Inspiron 17R-5737 Screen Replacement, RAM: 手順 7、 2の画像 2
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Screen Replacement, Keyboard: 手順 8、 1の画像 1
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Screen Replacement: 手順 9、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 9、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 9、 3の画像 3
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
  10. Dell Inspiron 17R-5737 Screen Replacement, Palmrest: 手順 10、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement, Palmrest: 手順 10、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement, Palmrest: 手順 10、 3の画像 3
    • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
    • Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  11. Dell Inspiron 17R-5737 Screen Replacement: 手順 11、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 11、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 11、 3の画像 3
    • Remove the two exposed ribbon cables.
    • Remove the palmrest.
  12. Dell Inspiron 17R-5737 Screen Replacement, Screen: 手順 12、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement, Screen: 手順 12、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement, Screen: 手順 12、 3の画像 3
    • Remove the display cable on the top-right of the motherboard.
    • Ensure the cable snakes through the path in the case when putting it back together.
    • Remove the two antennae from Wi-Fi chip.
  13. Dell Inspiron 17R-5737 Screen Replacement: 手順 13、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 13、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 13、 3の画像 3
    • Remove the nine 4.8mm screws from the hinges. There are four on the right and five on the left with a JIS #00 screwdriver.
    • Lift the display assembly away from the base.
  14. Dell Inspiron 17R-5737 Screen Replacement: 手順 14、 1の画像 1
    • Unsnap the bezel around the edges.
    • Remove the bezel.
    • During reassembly, make sure the wires are tucked inside the hinges so that they fit around the edges.
  15. Dell Inspiron 17R-5737 Screen Replacement: 手順 15、 2の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 15、 2の画像 2
    • Remove the one 4.8mm screw from each hinge cover with a JIS #00 screwdriver.
    • Do not over-tighten these screws during reassembly, as the hinge cover is thin and may break.
    • Remove the hinge cover.
  16. Dell Inspiron 17R-5737 Screen Replacement: 手順 16、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 16、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 16、 3の画像 3
    • Remove the five 4.8mm screws from each hinge with a JIS #00 screwdriver.
    • Remove one 4.8mm screw from the top left and the top right of the screen with a JIS #00 screwdriver.
  17. Dell Inspiron 17R-5737 Screen Replacement: 手順 17、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 17、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 17、 3の画像 3
    • Be sure not to damage the display cable when lifting the screen!
    • Slowly lift the screen away from the case assembly.
    • Unplug the display cable from the back of the screen.
    • Make sure there are no cables under the screen during reassembly.
  18. Dell Inspiron 17R-5737 Screen Replacement: 手順 18、 3の画像 1 Dell Inspiron 17R-5737 Screen Replacement: 手順 18、 3の画像 2 Dell Inspiron 17R-5737 Screen Replacement: 手順 18、 3の画像 3
    • Remove the four 3.2mm screws from each rail with a JIS #00 screwdriver.
    • Remove the rails from the screen.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
David Callahan
メンバー登録日: 10/19/17
559 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 UMass Dartmouth, Team S3-G7, Bailey Fall 2017人のメンバー
UMASSD-BAILEY-F17S3G7
3 メンバー
11のガイドは作成済み
2 件のコメント
I was able to do this repair on this exact model of laptop without dismantling the bottom half of the laptop. It’s not hard at all, all you’ve got to do is just separate the bezel from the lid of the laptop and pull it out from behind the base. It saves lots of trouble of dismantling. You can’t replace the hinges this way, though, but you can certainly replace the LCD itself without dismantling the bottom half of the laptop.
Joseph Sctbunio - 返信
But can I boot to an external display via hdmi if the main LCD is broken?
Brandon O - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 26
今までの合計 1,551
