はじめに
Audio speakers, while non-essential additions to a computer, are connected and function through the motherboard as an internal component.
必要な工具と部品
Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
Open the laptop to reveal the keyboard.
Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
On the bottom of the laptop, use the Phillips screwdriver to remove nine total 5 mm screws from the following locations:
Four screws at each corner of the laptop’s bottom panel
Two screws within the battery slot
One screw to the left of the hard drive
Two screws located below the RAM
Use the metal spudger at the bottom-right corner of the palmrest’s faceplate to pry underneath the plastic casing and separate the palmrest from the laptop’s bottom plastic shell.
Once the spudger has leverage between the two halves of the case, work the tool around the right, bottom, and left edges of the palmrest, prying the top from the bottom at around every half-inch.
Lift off the palmrest assembly.
By hand, unplug the four ribbon cables attached to the motherboard from the following locations:
The top-right
The top-left, beneath the WLAN card
The bottom-right
The bottom-left cable, attached to the speakers
Using the Phillips screwdriver, remove the four wide screws (2mm wafer) holding both the left and right speakers in place.
