はじめに
Located just inside the Inspiron’s access door, removal of the hard drive is designed to be a quick process and a prerequisite for the repair of internal hardware.
必要な工具と部品
Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
