メインコンテンツにスキップ
Dell Inspiron 1721 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 1721 Display Assembly Replacement, Battery: 手順 1、 2の画像 1 Dell Inspiron 1721 Display Assembly Replacement, Battery: 手順 1、 2の画像 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: 手順 2、 3の画像 1 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: 手順 2、 3の画像 2 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: 手順 2、 3の画像 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Display Assembly Replacement, Keyboard: 手順 3、 3の画像 1 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: 手順 3、 3の画像 2 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: 手順 3、 3の画像 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: 手順 4、 2の画像 1 Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: 手順 4、 2の画像 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 Display Assembly Replacement: 手順 5、 1の画像 1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 Display Assembly Replacement: 手順 6、 3の画像 1 Dell Inspiron 1721 Display Assembly Replacement: 手順 6、 3の画像 2 Dell Inspiron 1721 Display Assembly Replacement: 手順 6、 3の画像 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 Display Assembly Replacement: 手順 7、 3の画像 1 Dell Inspiron 1721 Display Assembly Replacement: 手順 7、 3の画像 2 Dell Inspiron 1721 Display Assembly Replacement: 手順 7、 3の画像 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 Display Assembly Replacement: 手順 8、 2の画像 1 Dell Inspiron 1721 Display Assembly Replacement: 手順 8、 2の画像 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Jason Haddox
メンバー登録日: 09/04/19
424 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 172
